Should I replace the power lead supplied with my Marantz CD6006 UK edition or a Yello Power Kimble Kable purchased in 2006? Cheers
The Yello cable is an upgrade from the standard cable that comes with the unit but it's about 14 years old.If you already have it why not use it? Am I missing something?
Thanks Steve. I'm inclined to agree with you but when I bought the 'upgrade' power plugs I really thought that was the way to go. Older & probably wider now!You've got both so try both. If you hear an improvement, keep it. I can’t see how you will, though, but it’s your call
