Hi-Fi Good Looking Racks
satycool
39
After finally building my 6 unit Cyrus system, I though it would be easy to find a Stand/Rack that would bring out the system in the room - esp as it cost me a lot!. After hours of surfing the web finding the right one became far more time consuming and difficult then I hoped, also far more expensive then I originally thought - esp for the ones I liked.
I listed what I found for anyone else in the same boat looking for that right rack that brings out the hi-fi and also looks good to look at. Some can be pricey though!
Narrow Less Wider Systems like Cyrus, MF M1,
Cyrus/M1 Custom Design Milan
http://www.audioelevation.co.uk/cartv3/Details_options.asp?ProductID=416
Cyrus (David Head Furniture)
http://handmade-kitchens.blogspot.co.uk/2011/01/alternative-to-cyrus-audios-hark-rack.html
Cyrus Podim XS
http://www.hifiracks.co.uk/hifi-racks/3/podium-xs
Wider Less Longer Systems like Musical Fedility M3/6/+, Naim Units, Marantz..etc
MagicRack M1
http://www.magic-racks.co.uk/products.html
Naim Frame
http://www.audioaffair.co.uk/Naim-Fraim-Hi-Fi-Stand-Shelf/product_6542http://www.audioaffair.co.uk/Naim-Fraim-Hi-Fi-Stand-Shelf/product_6542
Hi-Fis Custom Design Milan
http://www.audioelevation.co.uk/cartv3/Details_options.asp?ProductID=435
Poduim Trios/Reference (Custom Build)
http://www.hifiracks.co.uk/hifi-racks/1/podium-trios
http://www.hifiracks.co.uk/hifi-racks/2/podium-reference
7even System Glass Rack
http://www.soundandvision.co.uk/furniture/hifi-stands/7even-systems-vert-5
Stands Unique Glass Shelves/Wood Stands - Creative Audio
http://www.creative-audio.co.uk/STANDS_HIFI10.php
All Shapes
Apollo Glass-Real Wood Saprno
http://www.apollohifi.co.uk/Real/Real.html
Blok (Custom) Hi-Fi Stands
http://webcache.googleusercontent.com/search?q=cache:http://www.blokdirect.com/hifi-stands
Quatropica Glass Floating Mounted H-Fi Shelve
http://www.amazon.co.uk/Stand-Shelving-Shelves-Mounted-Modern/dp/B0027DMGXM/ref=pd_rhf_gw_p_t_4
Adona AV45 M Audio Rack
http://stereolist.com/hi-fi-audio/av45-series-m-audio-rack/
Soundstyle Wood 3 Shelf
http://www.theplasmacentre.com/tv-stands-and-av-racks/hifi-stands/st515-3-lo.html?bp=102
Triple Glass Wall Mount Xeno-3 & 4 Shelves
http://www.amazon.co.uk/gp/product/B0021BR752/ref=oh_details_o03_s00_i00
http://www.gandg-group.com/epages/61416851.sf/en_GB/?ObjectPath=/Shops/61416851/Products/AVFU
I got a blok rack quite recently and can thoroughly recommend them. I took the time to go a visit the factory before buying which was a nice option to have. A great product designed and built by a thoroughly nice guy.
satycool
39
I liked the BloK designs too, esp as you can design them to your preference and am considering them, but also like Custom Design Milan (Cyrus) with Accustic glass rack too - both racks look modern, elegant and well finished. Did actually get to see CDM in a shop display and they do really go really well with MF M1's as they were displaying.
The Wall Mount Xeno units are also pretty good - have them myself for my marantaz/sky/22"tv on the wall which look great and also hide ugly wiring while looking modern and elegant too - good for wider systems and can probably put two on each shelf. Good price too esp when compared to other racks/stands with a good quality build.
