U
		unknown
TrevC said:mikefarrow said:exactly. you would be surprised what basic/budget kit can do when better cables than the free (rubbish) ones provided are replaced.
only once i replaced the cheap/free cables with some better quality ones did i actually get to "unlock" what my kit was capable of.........
(try replacing your powermax plus with some russ andrews powerkords - you'll never feel like changing your hardware again !)
That's right! I put a Russ power cable on my old Bush radio and it now sounds like the musicians are in the room with me!. Even my lodger remarked on how much better it is than his top of the range gear.
I must fit one to my teasmade to improve the taste of the tea.
so what components/system do you use ?
what is your advice regarding upgrading hifi systems ?
or do you only do sarcastic posts ?
