Help! Which budget Sub and Surrounds?
Vimeous
22
A good friend is after budget-sub and sats for his expanding setup.
His current config is Arcam Alpha 3 Amp and B&W 602 S2.
He plans to add a Denon AVR 1610.
With a limited budget of £350 for centre, rears and the sub he plans to use the centre and rears from Q-Acoustic's 1010i package.
But which sub?
Suggestions so far:
  • Q-Acoustics 1000si
  • BK Gemini II
  • Monitor Audio R360
What do you think?
kage:Well The Q sub because it will probably be the best match...
Fair point. Having read the WHF review however it appears to have been a weak point in the system. Then again maybe, for the cash, you're dead right.
Would the Gemini be out of place?
While we realise a matching centre would be ideal (e.g. CC6 S2) the budget is tight.
