- Aug 10, 2019
- 2,556
- 5
- 0
Please can anyone help. Had a home cinema install done. Pioneer plasma, Jamo A102, QED micro connected to Onkyo 606. All cable chased into wall and room decorated. Retailer came to install speakers but both rears refused to work. Retailer walked away from job denying any responsibiliy, said it was plasterer damaged cable. Hacked cable back out where plasterer said he had moved cables. Couldn't find fault. So I cut cable (before where plasterer touched cables) just to make sure, still no sound. Spoke to wife (who was pretty angry by now) and she mentioned they drilled a hole for sub-woofer cable they forgot to install during 'first fix'. Looked at hole and the idiots had drilled through their own speaker cable.
They are coming out to do a 'repair'. They are going to splice the cable with some more QED. Each of the cables will have TWO splices between the Amp and Speaker connection. One where I cut and the other where they drilled through. It will be protected (apparantly) with a protective sleeve over the joins. I raised concerns about this over possible reduction in sound quality. They said it wouldn't make any difference. PLEASE can anyone back this up, or are they taking a lend because its easier and cheaper for them to do it this way ???? Sorry about rambling on, but as you can imagine I'm really ****** off, and would like a second opinion. Thanks for reading this !
