HELP/SUGGESTIONS NEEDED
I'm hoping you can help me choose my first quality TV.
I am looking for a 1080P TV size 46-50 inch.
I will have plenty of HD input ie Sky HD, Blu-Ray dvd player, Xbox 360 (for gaming occasionally). As well as watching High Def I will also watch SD quite often so if possible I would like a TV that has bang on (or as near as possible) picture quality for HD and SD looks good too.
I would like the styling of the tv to be nice if possible but not essential.
I will hook up a surround sound system so audio quality not a major factor.
The viewing distances will range from 1.8m to 2.1m - the tv will be used to watch alot of sport and movies by me and daytime tv on sd by the mrs.
Budget of upto £900
If anyone can suggest certain models etc it would be greatly appreciated.
cheers
IMHO to get what you are looking for in a 46-50 inch screen I would recomend upping your budget or opting for a smaller screen.
Panny 50G10 shouold be on your list, just over £900, as is the LG 50PS8000, top of the range LG model, with THX picture mode.
Under £900 are the LG 50PS6000/3000 models.
