Help please -my dvd signal has a green haze
Can anybody help.
I got a new Pannasonic PZ70 a few weeks ago and whilst I save the pennies for a HD Player I thought I would connect up my old Cinema surround system ( JVC TH A35 ) via Scart connectors. The only problem is that although you can see the picture it is all with a green haze? Even the JVC menue screen without a DVD in it is the same?
Neil
Hi Neil,
Sounds like a problem with your Scart lead or connection. I'd try using a different Scart lead first, then if there's no difference, experiment with different Scart sockets if possible, plus different connections (if your JVC offers them) to check it's not a fault with that.
Possibly TV expecting component and getting RGB from the DVD player? Or some other mis-setting between them? Or possibly a Scart that's not fully wired - ie not ready for RGB - sending only part of the signal to the TV?
my brother in law had a similar problem with his philips lcd over HDMI, turned out to be a problem with the tv.
i suggest trying a different component plugged inot the same scart socket to rule that out.
[quote user="richardjlarby"]my brother in law had a similar problem with his philips lcd over HDMI, turned out to be a problem with the tv.[/quote]
Well yes, there is that possibility too...
I've had a similar problem with a Philips dvd recorder and it finally proved to be the dvd itself (had to be fixed). Hope you'll get to the bottom of it. Good luck
I had this problem with my old Trinitron 16:9 CRT set. All the shadows (especially unshaven chins) looked green instead of grey.
I swapped leads and players and it was still there. The problem was with the set, and it's now in the loft........
