Hey All....
First Post on here, and was hoping for some advice.
I currently have a Yamaha DSP-A5. I have had it since 1999 or 2000. Its been a great little amp. I have loved it over the years, but now think its time to get into the HD Formats.
I have Monitor Audio RS6 Fronts, RSLCR Centre and a pair or RS1 for the rear. I am going to add another pair of RS1 or maybe the RSFX. Not decided on that bit yet. They are all hooked up with QED cables. I also have a REL sub, and, also have a sony 40inch 1080p LCD TC
I have around £500ish(maybe £600 just don't tell the other half that) to spend on a new AV Amp.
I have been looking at these:
Onkyo 606 or maybe the 875 as I have seen that for £599
Denon 1909 and 2309 and 2809
Yamaha 763 and 863
Sony DA2400ES and STR-DG820
At the moment my HD source is a PS3, But I am going to buy a dedicated Blu-Ray player at a later date. The new Amp is the most important thing right now.
I have been reading reviews and most of the amps are getting top marks. So unsure which will fit best into my set up.
So any advice on the above would be great. Anything else I sould be considering?
Cheers Stewart
Yamaha 763 and 863
Cheers Stewart
