I need a TV ASAP... No more waiting.
help me decide from a noobie who just likes watching good shows via amazon fire tv, blu ray movies ( NO SPORTS NO CABLE TV)
Room is 15'x25' with roughly 11' from the SET
I would like to spend between 2k - 3k (Might go up some if need be)
Id like to be 70-75" but would probably get a better quality 65" if I have to;
I never really owned a good tv only had roughly 32" so Id like advice on the best size if possble at my seating position.
What do you think?
thanks folks
What do you think?
thanks folks
