- Aug 10, 2019
- 2,556
- 5
- 0
I hope somebody can help with the following 2 questions:
1. What is the difference between the Pioneer 428XD and 4280XD, which I have? I'm very happy with the screen, but I wonder if there is a difference between the two models.
2. I have my Sky+ and Onkyo DVD Player connected by HDMI to the 605, which in turn is connected to HDMI Input 1 socket on the Pioneer. Everything works really well, except when I just want to listen to music played from the DVD player. The music plays fine with the screen turned on. However, if I try put the screen into standby, then the music mutes for one second, plays for 5 seconds, mutes, plays, mutes, plays and so on. None of the HDMI control settings on the Pioneer or the Onkyo seem to make any difference. The current settings are:
Pioneer: HDMI Control Setting [Input 1]:
Power Off: On
Power-on Ready: On
Hold Sound Status: On
HD AV Converter: Disable
Onkyo SR605: Hardware Setup: HDMI
Audio Out: Auto
Lipsync: Enable
xvYCC: Disable
Control: Enable
Power Control: Enable
TV Control: Enable
I have painfully gone through each setting in turn trying all options, but there does not seem to be a way to listen to CDs or MP3s without having the screen turned on. This doesn't happen when I listen to the radio using the SR605 Tuner.
Any ideas or suggestions would be really welcome!
Thanks in anticipation,
Dave Loewy
Power Off: On
Power-on Ready: On
Audio Out: Auto
Lipsync: Enable
xvYCC: Disable
Control: Enable
TV Control: Enable
Dave Loewy
 Facebook
Facebook Instagram
Instagram
