Help buying Cambridge cxa81 amp with speakers
Ian29
I am looking to buy a Cambridge Audio cxa81 amplifier and Kef R3 speakers
I am a simple plug and play petsonas I unfortunately do not understand technology very well. I have a Cambridge CXN streamer and I mostly use my iPhone to stream from Spotify. I listen to a wide range of music pop to jazz
currently have 30 year old Arcam amp and Rogers speakers and looking to upgrade
looking to achieve clear rounded sound
Whilst current set up is ok I think I am missing out
are the KEFs R3 a good match with the Cambridge cxa81?
Txs
daytona600
ast2312
31
6
45
Unfortunately I cannot comment on the K3’s but have heard the CXA81. It’s a very impressive amplifier. I found it very clean in its delivery. I tried it with a number of speakers all around the £400 range and all worked well. I just felt I was needing to spend more on speakers to get the best sound out of the CXA81 and in the end went for a different option.
Hope this helps.
Txs
I think you might be more concerned about whether the R3s are going to so work well in your listening room rather than matching them a to a particular amp.
