heat issue with onkyo 606
beater
72
i am looking at buying the onkyo 606 amp, but am not sure if it will be o.k in my cabinet because i have read they get hot when on.my cabinet dimensions are (w 540 d 440 h 200)with a back on, and the 606 dimensions are (w 435 d 374 h 174) will this be o.k.
professorhat
992
22
18,895
With a back on - does that mean the cabinet has a back (I know it sounds obvious but, just checking!). Main reason to ask is, that only leaves you 66mm for the cables to be plugged in at the back which I don't think is enough meaning the 606 may well stick out the front of the cabinet (let alone the cooling issues).
If the back is open, I think those dimensions would be okay, but not if the back is closed.
beater
72
thanks for your reply.yes that is with a back on, but i do have a denon 1906 in there at the moment and that is the same depth as the 606 and that fits in there o.k.
Big Chris
400
Can you cut the back out?
I did this with my unit. Measured the height and width of the amp, and then cut the back out slightly smaller than the measurements. Amp pushes back farther. Connections are all hidden behind the unit, not within it. Additional circulation provided. And from the front you wouldn't even know that anything has been altered.
