Hearing a superior system - what does one do?
lindsayt
16
arashid said:
it almost obvious where your issues are
you need to upgrade your source.
your rdac is good for the money, but it cannot be compared with a NDAC.
An upgrade to the OP's source wouldn't do any harm. Yet I bet I can come up with some speakers that will make his rdac / 5i sound better than his mates Superuniti / rega system. Better on good recordings as well as better on poor recordings.
steve_1979
231
10
18,795
I disagree. :)
Changing the DAC will only make a minimal (if any) difference to the sound.
If the OP wants to change to the way his system sounds then he should start by auditioning different amplifier and speaker combinations
cheyworth
145
For me the only time I will have a problem with the sound from my system is if I hear a better sound coming from the same kit in a different system!
bluebrazil
19
i think the dynos need more power than the 5i can muster, upgrading the dac first wont get the best out of your speakers.
then again you could change your speakers first, but like you i love the dyno sound. its a pity tho that they need a lot of current to get them sounding good at modest volume.
bluebrazil
19
back to the original question tho, it doesnt bother me if i hear a better system and mostly its just certain aspects that you notice.
i find it rare to hear a well matched system that does everything well in somebodys home. the nicest i have heard was a modest marantz and tannoy system that just seemed to sound as i like. i guess thats because we all have different ideas of what is a good sound.
