Hi have got a little confused after reading the new mag.
I am or have pre layed cables in a new build. My av is in the lounge serving 1 out to the tv above & 1 out to the tv in the kitchen, all served by a sky+ & blu ray into the av ( no final decisions on eqpmt). From the tv in the kitchen to the av amp i have 1 opt & 1 phono, should i lay a high speed hdmi into the av ?, after reading the mag i think it means if you have a tuner on the tv then you need an hdmi out to the av for sound ? can you help i have 2 days before the plaster board goes up. What should i pre lay ?
The TV in the kitchen has freeview tuner so can work independently to the lounge also i would like to have the front l/r speakers in the kitchen going through the AV but trying to listen only to those & not the whole lounge set up as well is this possible ?, hope this makes sense i thought i was nearly there but think i have missed some thing,
thanks for your help
