professorhat:Hey Garth Man, in long, yes.
In long, Yessssssssssssssssssssssssssssssssssssssss.
No reason to do that really, except I'm a bit drunk. Oh, and that I've personally tested different HDMI cables and found that there are differences. No idea where the concept above came from i.e. "digital was created for that very purpose, analogue signals can be distorted and repaired slightly, but digital is either on or off. unless there is something wrong with the cable, its fine" but I'm afraid this statement is without certainty not true.
If you can find differences in the cable, and am happy with stumping up the extra, then far be it from me to say your opinion is wrong.
My reasons for my answer were that. if we go back to year 8 science, remember digital/analogue graphs.
Digital signal is transmitted down the cable as either a 1 or a 0, on or off, so when the signal is received the other end, the decoder can easilly distinguish if its on or off, no signal degredation possible (unless over extremely long runs)
Whereas with analgue, where a point on a waveform could represent, as an example, any number between 1 and 30, and lets say through distortion it should have been 15 and was distorted to 18, the processor could assume the intended value was 17, thus being a 'loss' on the original signal path.
My opinions also go on the fact that ive seen a lab test between HDMI cables where a computer was used to put a signal through a HDMI signal and analyse the resulting signal, they tested 4 cables running from costing £7 to £250 and the results were uniform, absolutely no difference in the signal whatsoever. And thats computer physics.
www.hdmi.com will also tell you that, as long as a cable is HDMI compliant, you wont notice a difference.
I have also done private tests, with a £12 cable i got off play, and a £130 monster cable my father had, we were unable to notice any difference.
Bottom line - (In my opinion) is that as long as a cable is of reasonable quality, there is no point spending the extra.
Apologies professorhat if you think I may be adding fuel to a fire, but ive seen just too much evidence to suggest there is no difference whatsoever.
