hd sound confusion!
hi there! just a bit confused with the transition to hi def. i have a pana ae2000 1080p projector ma rs6 av speakers and roksan power amps. i'm currently using denon 3910 and 3805 amp for dvd's.
i want to get a blu-ray player (panasonic dmp bd30) and get the most out of my projector, but will it sound better than my current set up? will i get dts hd master audio, lets say, out of a 5.1 analogue output? or will it just be dts. and do i have to get an av reciever (onkyo 875) to handle the hd sound via hdmi?
any advice? thanks.
It'll work fine, but you'll need to use the multichannel analogue outputs on the Panasonic connected to the matching analogue inputs on the Denon.
But three sets of cable will cost you a lot less than a new receiver.
that would be good as i already use chord chameleon interconnects between the denons!
