HD AUDIO
Pansonic PZ81 t.v, Yamaha dsp ax640se surround amp,kef kht 2005.3.Chord optichord.chord hdmi 1.3a.chord carnival silverscreen speaker cable
I am just about to buy either the Panasonic dmp bd 35 or the 55.
Can anyone tell me if i can get hd audio through an optical cable, as the bd 35 has no multichannel out, but the bd 55 does.
My amp does not have a hdmi IN but it does have optical IN.
Cheers.
Fast freddie.
what type of cable should i use to connect my center as there is only one input on rear of the yamaha amp
Sorry about being a bit vague!
Hooking up a pana dmp bd 55 blueray to my yamaha 5.1 surround amp using analogue cables so i can get hd audio formats.
1x pair for my main fronts
1x pair for my surrounds,
But there is only one input in the rear of my amp for the center channel.What cable would i need to connect from the center OUT on the blueray to the center channel IN on my amp.
cheers.
Just a conventional single phono cable for the centre: so two for the front L/R, two for the surround L/R, one for centre, one for subwoofer.
And it's three strikes and you're out on that username you keep registering. Please choose something less offensive, as I'm bored with continually changing it.
Sorry its so offensive.i.m changing it now.
It was a title from an episode in Faulty Towers.
Chill.
