Please could you suggest what AV systems I should buy, considering:
~ I’d like to buy the Samsung 8000 model, size 55 inch for my 4.5 x 4.8 sized room. I like the sharp screen resolution and brightness (even if the image is a little unnatural vs the Panasonic VT 30 range). I like the ‘remote’ also, that ‘mini’ screen on it plus is touch sensitive. Should I wait for the ‘E’ 2012 version with Kinect features, and do you think it will come April?
~ if floor speakers are better quality for same price, happy to go with these, otherwise can put on walls
~ spend: thought TV is £2k, happy to spend circa £5k for amp/speakers (majority of spend), plus blueray/cd /dvd/streaming devises
