Hi Folks - I’m just about to order a new turntable and wondered if you could help with a few wise words please?
I'm aiming for a neutral sound with very slight warmth as compromise for easy evening listening, a crystal clear detail and a full and well defined base. My amp and speakers are ATC SIA2-150 and SCM40’s.
I thinking Gyro SE - £1,700 / RB2000 or SME M2 - £1,400 / Cadenza Blue - £1,300 (I assume this will suit and fit these arms TBC) / Rega Aria - £800.
There are so many combinations that I can’t possibly listen to them all, but I will listen to this lot before final decision;
-- Have I got the cost relationship about right between the various bits?
-- I’ve read some reasonably good reviews about these arms, but is there anything else I should try? Are these considered a sensible upgrade to the Technoarm?
Many thanks in anticipation.
Regards
Steffan
Regards
Steffan
