Genelec Active Speaker Selection Tool
  • Thread starter Thread starter the record spot
  • Start date Start date
T
the record spot
Check this out - found this on Genelec's excellent site. It allows you to input some details via their very easy to use application. Once you've defined your requirements, it comes back with a list of speakers that meets the specifications you've entered. Great little tool. Click below for more:-
http://www.genelec.com/learning-center/speaker-selection/
Funny little test. I was recommended the Genelec 8030A
Isn't it about time you go out and get yourself a Genelec speaker Mr. the record spot? You have been mentioning them quite a few times, and they are not that expensive are they?
