front left speaker crackling/buzzing..........
Gerrardasnails
295
Yesterday I moved my equipment about and now my front left speaker is giving off a noise like a buzzing/crackle. It only happens when I have my speakers working with my AV receiver (connected to my stereo amp via pre outs). The cable (Odyssey 4) sits over numerous other cables before reaching the 840A. Could this be the cause, interference from the other electrics?
mikegtar
36
Yes, it's quite likely to be the cables - power, speaker, interconnects. I had the problem the other day and it was one of the interconnect cables. Tidy them up as much as you can. Also, the standard I.T. trick is useful to bear in mind : "If in doubt, plug it out". Plugging cables out makes it easier to unravel them and also ensures the the connections are not loose. Worked for me, hope it works for you to.
Gerrardasnails
295
mikegtar:Yes, it's quite likely to be the cables - power, speaker, interconnects. I had the problem the other day and it was one of the interconnect cables. Tidy them up as much as you can. Also, the standard I.T. trick is useful to bear in mind : "If in doubt, plug it out". Plugging cables out makes it easier to unravel them and also ensures the the connections are not loose. Worked for me, hope it works for you to.
Cheers. All sorted now.
