Focal Chora 826 Buzz tweeter
Radosevic
Hello, I noticed buzzing sound problem at my new Focal Chora 826 tweeters with new Marantz NR1609 receiver. I heard that when I listened piano tracks on both speakers. I tried to play piano tracks with AirPlay (16bit 44.1kHz), S/PDIF (24bit 192kHz). I tried with Pure Direct mode, but same problem. I recorded it with my phone near tweeter, here is attachment: https://gofile.io/d/40wctV
Thank you!
Gray
Thank you!
The only brief 'scratchy' bit I heard was at 14 seconds, but it's probably only your movement when stopping the recording?
Others may hear it differently.
Unlikely that there would be a fault with one, let alone both tweeters, if that's what you're worried about.
Radosevic
Thank you for you reply, yes at the end was my movement. I'm worried about the distortion that is heard during the recording, in every solo piano track.
Deleted member 108165
I can hear it. I think it sounds like a problem with the actual analogue recording. How old is the recording?
ASK THE COMMUNITY
