bigboss said:
			You need to demo a properly set up Atmos in a home to really appreciate the benefits. Too bad if you can't set Atmos up in your house for whatever reason, but that doesn't mean Atmos is rubbish or gimmicky. You're welcome to demo at my place.
Certainly wouldn't say no to that! Having a look at your system and your theater room in general, it certainly looks fantastic! Very clean installation with an inviting atmosphere! Kudos to you for that!
*good*
For the record; I'm not being a skeptic just for the sake of it. I can only go by what I've heard and prefer. I've experienced two immersive audio systems in domestic environments and another in a treated demo room at a dealer. One of them had those horrific add-on speakers (a terrible concept if you ask me) and the other two were 'proper' installations with either in-ceiling or on-ceiling speakers (four in total). Each system I was told had been calibrated. One of these were pretty good with selected scenes from certain source material but overall the immersive systems did not wow me the way I expected them to. Things sounded a bit 'off' at times to my ears, sometimes muffled/diffuse and other times lack of overall soundstage focus. The moment I switched each of these systems to 'direct' in order to play the core soundtrack things snapped back into focus. Yes, the overhead effects were lost but otherwise things felt more accurate and natural to my ears.
Even though I know it's not the same thing because this is object-based audio, the experience reminded me of the front height and side width speaker algorithms from a few years back. I didn't care much for the effect of those either. But that was more or less pseudo-effects, right? This is supposed to be different. Even so... it's not discreetly mixed channels for the home environment. I know folks who went for set-ups like the previous ones but who have now scaled things back to 'normal' set-ups because at the end of the day it sounds better to them.
In all sincerity the task and knowledge of properly implementing 11 channels or more and doing it equally well for each and every speaker is no cakewalk for most domestic dwellers with merely a living room at their disposal (and limited know-how). If you have a dedicated room, perhaps, with the appropriate funds/time/energy/determination to go all out on maximum fidelity per installed speaker then ok... all the more power to you!
I'd much rather stick to a "standard" speaker set-up myself and continue working on improving that. More speakers will not make me happier at this point. Better room acoustics with improved fidelity from of the current ones will.
Just my two cents. Nothing more, nothing less.
*smile*
