gasolin said:
Size matters (bass)
Have Q Acoustics 3020 (just collecting dust until someone buys them) and i use as you can se in my signature Mission LX-2, reason, i wanted more bass
The mission's are alot bigger and they have more bass than the 3020's "size matters"(for better balance)
In a small space,room with your computer, floorstand speaker almost never gonna sound at there best,often to much bass and more difficult to place them compared to where you sit (have seen alot of youtube videos where floorstand speaker are placed behinde the desk (almost like rear surround speakers) instead of infront of you on each side of the monitors or behind the computer,desk), that's where small speakers are the best, in small rooms, where they can sound better than floorstand speakers
To me most bookshelf speaker are loud enough, it's just if you have a big room you need big speaker to get the bass to fill the room,personally i don't need a very deep bass, as long as i can hear it,it's loud enough and sounds good, not just boomy,oomph oomph
Bass to me makes the biggest difference between booskshelf and floorstand speakers, not so much the max spl since many good booskshelf speaker can handle above 50 watt, which is loud and many (dynaudio) can handle above 100 watt
If you want mid sized bookshelf speaker with good bass try Dynaudio Emit M10/20 they have alot of bass
Although bigger, your LX2's still only have a cone area only slightly bigger than the 3020.
They will have slightly more bass but in reality bottom out almost at the same frequency usual for most small speakers. Mission also have that traditional upper bass lift to give the impression of more bass. Perhaps the QAcoustic guys chose to not do that. Both speakers will have similar loudness limitations.
Neither would be a good choice for larger rooms and/or high volume.
At 50 watts your Mission's and the 3020's light and small bass/mid drivers will do the fandango and double into a high distortion frenzy made obvious by softening of bass.
High power/volume requires serious drivers both in size and construction and a larger cabinet.
To make such a speaker costs money.
The Dynaudio is probably a good suggestion as they usually use slightly larger drivers in still small cabinets. They are also better constructed and the polyprop cones and larger coils and magnets will handle a little more volume. The pay off is usually lower sensitivity and more power required. They will probably also not sound their best at low volume.
