Electrostatic Speakers - Pros and Cons
Overdose
279
I thought I'd start a new thread about the pros and cons of electrostatic speakers, as potentially interesting info for some, might get lost amongst another meandering thread.
So for those knowledgable on the subject, perhaps you would like to contribute.
I know very little about them apart from the spelling, so would someone else like to start? :)
jerry klinger
37
Cons:
There aren't many around, they cost a lot, they're difficult to drive, they need mains power, they're big, they often don't sound like they have much bass.
Pros:
People who use them won't use anything else due to lack of treble and midrange colouration.
hoopsontoast
12
Just Electrostatic speakers, or panel speakers that use other technologies like Ribbon and Planar?
Both have similar pro's and cons.
Electrostatics usually have quite low dips in the mid-treble impedance so need an amplifier that does not mind that, but they are relatively benign at low frequencies. They also require a power cable to energise the electrostatic panel.
An example of the Electrostatic speaker are the Quad speakers, like the ESL-57, 63 and the newer models. Martin Logan have Electrostatic mid-treble and hybrid dynamic cone active bass in most of their models, and some of their high end use Electrostatic bass panels I believe.
Some others are Kingsound, B&W made a hybrid back in the 70's and a few others.
Panel speakers like ribbons, or planar tend to have a purely flat and resistive impedance, thus making them very easy to drive, although usually at low impedance (4 Ohms) and are quite in-sensitive so require a lot of power. They do not require mains power to the speaker.
Magnepan uses both Planar technologies (bass panels in all their speakers, and hybrid treble in the MMG) and then Ribbon tweeters in the higher end models. This is the same configuration as the Apogee speakers.
Both types have advantages in that the whole panels are energised, so you have a line source that moves the air, resulting in a very large and quite lifelike soundstage. As most, if not all are dipole speakers which means they radiate to the font and back in a figure of 8 pattern. This means that bass acutallu cancels it self out at the sides of the panels, which means they can be placed near to side walls. They need a reasonable amount of space behind them as the the bass-mid-treble are radiated both ways so can muddle up the sound.
Both types also have limited vertical dispersion, the curved panels of the Quad ESL-57 help with this.
I am sure others will add more, thats just all I can think off at the moment.
hoopsontoast
12
Subjectively, IME with the Quad 57, Magnepan MMG and hearing other 57's, 63's and Apogees they have a great big soundstage, very natural presentation, open midrange and lightening quick bass with no overhang (dipole).
They tend to re-produce drums especially well, and vocals.
richardw42
299
Size is a major factor but I think I could get away with them in my lounge as there's quite low traffic and their position would be quite out of the way.
I was speaking to somebody the other day who previously had some Quad ESLs, he said they had the sweetest of sweet spots but dropped off if you ventured out of it.
Something like the Martin Logan hybrids are really interesting. I'd love to hear them.
Overdose
279
Given that electrostatics are/can be difficult to drive, wouldn't active amplification be better, perhaps active/powered electrostaics and planar speakers are available?
Regarding the problem with dipole transmission and placement near walls, could this be minimised with acoustic panels behind the speakers?
altruistic.lemon
64
Hoopsontoast, you've described electrostatics and panels far better than I could, spot on. I've found them a bit less fussy (Maggies) than some have. Worth saying the bass cuts off absolutely at whatever the bottom level is.
Apart from the logistics of having active panels, why would you bother? They outperform most other speakers at their price and above.
Apologies for going off topic if you meant this thread for electrostatics only - they are radically different to panels.
hoopsontoast
12
You could go active, but one good thing about a passive crossover, is it has protection for the very fragile (electically) tweeters. If in an active crossover, the amp went puff, it would take the tweeter with it. Often, like in the case of Magnepan speakers, they have an inline fuse to stop that happening.
Things like Quad 57's actually like being driven with valve amps, as long as its stable its a match made in heaven. They were designed to be used with Quad II's and even the 303/404 SS amps.
Acoustic Panels would certainly help with dipole radiation to the rear.
bluedroog
8
They need good space behind them to work well as they can produce almost as much sound from the back as front so need room to breath.
Done well they can sound superb.
hoopsontoast
12
A brief explination of Monopole Vs Dipole Radiation on speakers, remember that the rear wave will be out 180deg of phase with the front, and you can see the cancellation at the sides.
http://www.acs.psu.edu/drussell/demos/rad2/mdq.html
andyjm
15
I have Martin Logan hybrids, driven by Krell amplification.
Very fussy to set up, toe in, distance to rear wall and overall placement key to making them sound decent. Sweet spot is small, both vertcally and horizontally.
I have a relatively small room, so ended up placing acoustic panels on the walls behind the speakers because of the dipole effect mentioned above.
When setup well, particularly for female volcals, they do their amazing disappearing act. 5 minutes with a decently recorded CD, and all the hassle is worth it.
CnoEvil
556
14
OD, I did something similar a while back, so in case there is some useful info, here it is: http://www.whathifi.com/forum/hi-fi/electrostatics-brilliant-answer-or-impractical-solution
BenLaw
475
7
18,895
http://forum.blu-ray.com/showthread.php?t=66471
Another interesting article on dispersion patterns and the cause and effect of comb filtering with dipole speakers. The way it's been explained to me is that this effect is at least partly responsible for the great soundstage and the feeling that the speakers disappear. This effect is particularly good for classical music as it replicates venue acoustics but in terms of high fidelity of a studio recording may not be the best. It also limits the sweet spot a great deal, so don't listen with friends, especially very short and very tall ones!
WinterRacer
34
I asked this question on another forum as I remember hearing some large hybrid electrostatic/MC speakers many years ago, thinking they were amazing and wanting to know more.
"They have limited dynamic range, they tend to distort on LF, they are not terribly reliable and they beam, so there's only a narrow sweet spot.
They also suffer break up problems. The Quad ESL63s are the most intelligent in this respect, because they use delay lines to excite annular rings that start in the middle and work their way outwards.
They idea is to excite the diaphragm (it's like a large sheet of clingfilm) from the centre outwards as a stone causes rings when you drop it in a pond. Trouble is that a pond may be large enough for the rings to disperse before they hit the edge, but an Electrostatic isn't. The ripples hit the frame the diaphragm is miunted in and bounce back inwards disturbing ones on the way out. This is distortion.
The long and the short of all this is that although they can be shown to be technically flawed, there is no question that they can sound stunningly good with material that suits them. They are very realistic.
The problems with Quads and Martin Logan's was that diaphragms harden with time and sensitivity drops, they attract dust that causes arcing, which blows holes in the diaphragm and so on, so they never were as reliable as cones."
CnoEvil
556
14
I can feel a storm brewing..............
CnoEvil
556
14
WinterRacer said:
Sorry if it does, that wasn't my intention. I thought the text was quite balanced, I.e., technically flawed, but can sound stunning.
I found it informative......I knew about some of what was said, but not all. The subject can cause emotive reactions.
Overdose
279
It would be useful to have a thread for each of the main speaker types that were factual and ideally non emotive, as a useful reference for newcomers to the respective technologies.
This thread, so far has had some good info and I could see me at least trying something like planar or electrostatics in the future, just not yet and in my current house, as they would simply not be ideal.
oldric_naubhoff
23
good thread OD. (finally something's happening on this forum). for the interested I think this article sums up very well advantages of ESLs over dynamic drivers. if you really love your dynamic speakers, be it active or passive, and you think you'd never swap them for anything else read this article only at your peril.
http://kenrockwell.com/audio/stax/electrostatic.htm
those who know me here know I don't like waxing lyrical over the "sound". hard technical facts is what matters most. and this article is quite technical. but also very approachable to everybody.
oldric_naubhoff
23
ESLs usually have inherently difficult impedance plot that stems from driver technology and not from using a passive crossover or not. connecting a power amp directly will yield no benefit. besides ESLs don't suffer from back EMF so no need for high damping factors. besides, the interface transformer windings would screw up nicely even the lowest of damping factors.
the bottom line is you really need a capable amp to drive ESLs efficiently. such that is stable into low impedances, even as low as 1 Ohm. the upside is that the usual impedance dip occurs in high treble region where is really little musical energy.
Overdose
279
Thanks for the link.
I liked his DACmagic review and it was partly responsible for its purchase, along with a special price of £250.
busb said:
I heard a pair of Quad electros around thirty years ago, probably driven by quad prem/power. They sounded stupendously good - no boxiness, beautifully integrated across their frequency range, smooth, detailed with good imaging. Their bass was their greatest weakness: not deep. Upper treble wasn't brilliant.
The nearest speaker I've heard recently was an oldish pair of column Grandiants that have to be up against a wall to produce bass which actually goes quite deep. These speakers are triangular in cross-section with the dual driver mounted on an internal frame, therefore no box that does give a clean sound with fewer artefacts than my Arros. For a speaker that needs a rear wall, they image well if not up to the standard of mine. So there are alternatives to electros.
Thanks for your views.
oldric_naubhoff
23
hi BenLaw. the article is quite long and I didn't want to go through it all. could you post the excerpt explaining why dipoles would be comb filters? this is the first time I came across such a notion and I'd like to know where it's coming from. thx.
