Hi, hoping someone can help.
On converting my garage to a playroom and study 4 years ago, I took the plunge and had some "home cinema" built into the two new rooms. Current system consists of Hitachi 42" 42PD5300 plasma, without speakers, housed flush into a hole in the wall in the playroom together with a 5 speaker B&W in wall/ceiling system. The Hitachi monitor is hooked up to an AV3000E TV receiver in the study via a DVI cable buried in the wall and running between the two rooms. The receiver has a standard TV arial feed (not really used), a Sky+ feed, and a DVD feed from an Arcam DV78 also in the study. These sources feed an Arcam AVR 200, again in the study, powering the B&W speakers through buried QED cabling throughout. I'm now looking to upgrade to HD (the Hitachi is not HD ready) but wondering how this can be best achieved given I'm limited by the size of the hole in the wall as to what monitor I can use (monitor needs to be 105 cm by 65 cm max) and that I can't change the DVI cable for HDMI. Will upgrade the Sky + box to Sky + HD or FreeSat. I can't switch the DVI cable to HDMI as this is well and truely buried in the wall.
So what options do I have regards a new monitor? Will I still need an external receiver? Will I also need to upgrade my amp to make the most of the new sound formats and the fact the Arcam has no HDMI ins or outs? Should I even bother given the Hitachi cost me £3300 4 years ago and is probably worth diddly squat now?!?
Appreciate your advice please.
