EAC Ripping issue
mcjwalters
76
Is there any way to get EAC to copy disc as the origanl is played i.e if the track has no gap and leads into the next track it does this without leaving a gap as well as the track listing not reverting to alphabetical.
Mark
To burn a copy of a disc that plays in that way, iirc your optical drive needs to support gapless Disc-At-Once (DAO) burning, as does the software obviously.
Honestly easiest to just rename the files to the track numbers.
I've just recently started to use EAC but as far as I have seen it should make an exact copy including gaps. Just use the CUE file generated during reading.
Regarding track listing, I've ended including track number in the name.
ÿ
Cheers!ÿ
