Dragonfly v1.2 - USB DAC Asyn.
gasolin
Snoopius said:
anyone here knows if dragonfly v1.2 is compliant with linux ubuntu 15 ?
thx
I think so but it says:
DragonFly is an affordable and easy-to-use device that delivers far superior sound by bypassing the poor quality sound card that is built into your computer. DragonFly is a sleek, flash drive sized Digital-Audio Converter that connects to a USB jack on a Mac® or Windows® PC, turning any computer into a true high- fidelity music source. on there website
Won't bother with it since i personally never could adjust bit and samperate when i a few years ago used linux,why use a high quality dac if you can't easily change bit and sample rate (with the dragonfly you can only change samplerate)
