Same hereMUSICRAFT said:Hi ellisdj
Look forward to the review
All the best
Rick @ Musicraft
I got it as when I'm at work I'm using 600 ohms earphones with a crappy laptop. Not ideal. So I had a choice different headphones or a dac/ampellisdj said:I have literally just got one as well and will be doing a review of it![]()
That looks very interesting. What headphones do you use?gasolin said:I use this https://hifimediy.com/DACs/ready-made-dacs/Sabre-9018-DAC and it's pretty much one of the best and i eeven bet it's better than the dragonfly black
Very interesting indeed. For such little money you can't go wrong. I suppose this will be perfect for anyone looking to built a computer based hi-fi system.gasolin said:don't use any headphones, just from my pc to my amp
https://translate.google.dk/translate?sl=da&tl=en&js=y&prev=_t&hl=da&ie=UTF-8&u=http%3A%2F%2Fwww.lydogbillede.dk%2Ftest%2Fhi-fi%2Fhifime-sabre-9018%2F&edit-text=
If you say you speak to God then you are considered religious, if you say God speaks to you then you are considered psychotic...gasolin said:Yes, it's cheaper than the dragonfly black and wouldn't be surpriced if it sound better than the dragonfly red.Native_bon said:Very interesting indeed. For such little money you can't go wrong. I suppose this will be perfect for anyone looking to built a computer based hi-fi system.gasolin said:don't use any headphones, just from my pc to my amp
Like the nad 3020, really god sound for almost no money
Your just limited to minijack and what ever you can get,need at the other end and optical output (the one that looks like a mini jack)
Tak, gasolin.gasolin said:don't use any headphones, just from my pc to my amp
Im god my tiny dac kick's audioquest's buttAl ears said:If you say you speak to God then you are considered religious, if you say God speaks to you then you are considered psychotic...gasolin said:Yes, it's cheaper than the dragonfly black and wouldn't be surpriced if it sound better than the dragonfly red.Native_bon said:Very interesting indeed. For such little money you can't go wrong. I suppose this will be perfect for anyone looking to built a computer based hi-fi system.gasolin said:don't use any headphones, just from my pc to my amp
