Does anyone know the 4 digit remote code for....
Big Chris
400
BT Vision? Also, will any of the regular Sony DVD codes work with my 350?
And why-oh-why can I get my 875 remote to control my Arcam CD no problem, but I can't get it to operate the volume or mute on my Arcam amp?
EDIT: Scratch the Arcam problem. Just set it up so the direction button in the centre of the Onkyo remote does vol (up and down), and track (left and right), with mute as the enter button in the centre.
Looks like I can consign the Arcam remotes to the cupboard now. Helps cut the clutter...
Big Chris
400
Tried all the remote codes for Sony DVD, none of which work on my 350.
Can anyone with a 350 (or 550 I guess) shed any light on the remote code?
rob_981
82
I had a similar problem with the s350 and my Sony all in one remote - I couldn't find any codes to work. In the end, I had to program in each button individually using the key learning function. Does your remote have this function? If so, you might have to do this. Mine is working perfectly now.
