T
BenLaw said:Thompsonuxb enjoys trolling on this subject, don't feed him.
nawty said:Indeed, BNC is/was the way to go and have you ever seen an expensive BNC cable or bling connector? 🙂
nawty said:Do you know if HDMI corrects these issues, I assume it does? (I've not kept up to date with new developments)
the record spot said:No, there's an element of aggressiveness, or something not far off it. The manner in which the "challenge" comes out is hardly unbiased, neutral or the like - "I'll settle this thing once and for all". What? Opinions? I imagine you've just found a job for life.
the record spot said:It's pretty simple really - you won't "settle" anything "once and for all". This argument's gone round the houses on any number of internet fora never mind this one. Nothing to settle in the end.
Thompsonuxb said:the record spot said:It's pretty simple really - you won't "settle" anything "once and for all". This argument's gone round the houses on any number of internet fora never mind this one. Nothing to settle in the end.
And it will keep going round the houses, but if we get together and do such a test then surely there will be some settlement. Even if we take a democratic vote amongst ourselves. As far as this forum is concerned it will be settled. Because we will always have this as a point of reference.
When the topic raises its head again we can then say "ahhh...but in the "Differences in interconnects test" we carried out 29/04/12 in birmingham at Superfi we concluded that......."
the record spot said:Thompsonuxb said:the record spot said:It's pretty simple really - you won't "settle" anything "once and for all". This argument's gone round the houses on any number of internet fora never mind this one. Nothing to settle in the end.
And it wouldn't solve anything - you'd get, what, however many Superfi can hold (assuming they've bought in to the concept - and in the event nobody does hear a difference, whither their sales of cables then...), so ten, twenty? How many people have signed up to this site? Thousands. You'd get a nice day out, a bigger version of the Big Question at best and most people none the wiser.
Thompsonuxb said:Forget excuses, do the test, maybe others could organise their own tests closer to home, I know people will hear differences, I'd do the test I am not afraid..... 😉
oldric_naubhoff said:nawty said:Indeed, BNC is/was the way to go and have you ever seen an expensive BNC cable or bling connector? 🙂
nope 🙂. but I'm sure if BNC was widely used in home hi-fi many would emerge.
Thompsonuxb said:Cables do make a difference.
Note those who will claim they don't, appear to be the most reluctant to do a simple test such as the one I propose. A controlled enviroment a fixed set of parameters only the cables/interconnects will be changed and we listen. its not even a which one is better test.
And why don't some of you trust what you hear, I mean believing your mind is playing tricks on you if you hear a difference......whats that about?
Regards digital interconnects - fibre optic, copper or silver. the more expensive the cable the purer it will be. Its like diamonds to a degree. why do two stones, same size same weight have different value. considering they are both diamonds. Could it be that one is clearer, purer than the other.
If you can understand that then why is it so hard to believe this will have an affect on an electrical signal passing through it. I am confident in a test such as this you will hear the differnces in cables, both digital and anolog, confident enough to put good money on it....my car tax is due and It could do with a service too.
I'm not desperately looking for friends, but c'mon lets do this settle the argument....I dare you.
Thompsonuxb said:MUSICRAFT said:Thompsonuxb said:BenLaw said:Thompsonuxb said:Digital interconnects make more difference than anolog by the nature of the digital signal. Its more precise and less splashy at the top end
I don't really know what that means, but can you provide a link in support?
Provide a link, what for......lol.
If you have access to a digital reciever connect your CD player to it directly with digital/optical coax, compare them to Anolog interconnects and agianst each other and then hand on heart report back and tell the truth......provide a link......indeed.
Hi Thompsonuxb
I use a basic (single) interconnect to transfer digital data between a Yamaha BD-S1900 Blu Ray player (coaxial digital out) > Chord Electronics DSP8000 AV processor.
Btw, for optical connection i use a basic fibre optic cable which i bought at the local market for a £1.
All the best
Rick @ Musicraft
I know, you keep saying you do......I don't know if you're just cheap or you really don't have that set up...er...set up to really listen to your music.... you have a shop Rick ? lets all go to Ricks shop to do this test.
MUSICRAFT said:Thompsonuxb said:MUSICRAFT said:Thompsonuxb said:BenLaw said:Thompsonuxb said:Digital interconnects make more difference than anolog by the nature of the digital signal. Its more precise and less splashy at the top end
Hi Thompsonuxb
All the best
Rick @ Musicraft
Hi Thompsonuxb
If i was cheap do you really think i'd buy a DSP8000 at £13k or the matching SPM3005 multichannel power amplifier at £15k :? If i wanted to i could have 'blinged' up these and other components such as a Plinius Hiato, Krell FPB600, etc. with after market cables.
All the best
Rick @ Musicraft
Alec said:MUSICRAFT said:Thompsonuxb said:MUSICRAFT said:Thompsonuxb said:BenLaw said:Thompsonuxb said:Digital interconnects make more difference than anolog by the nature of the digital signal. Its more precise and less splashy at the top end
Hi Thompsonuxb
All the best
Rick @ Musicraft
Hi Thompsonuxb
All the best
Rick @ Musicraft
Wave it in our face why don't you.
But seriously, the minimum you should be spending on even just the mains cable for that little lot is £500, easy.
Ambrose said:OK, I see I have started another argument off here..... sorry folks!
I did receive my Mark Grant coax and had an hour or so last night switching back and forth and so far I cannot report anything conclusive (in my mind). I think I prefer the old coax cable codac and think I maybe hearing differences but...but....I just have no definate opinion yet.......
I will run new cable in for a day and try again as smaller differences tend to be more noticable over a period of time to me.
ON THE GENERAL DISCUSSION ON CABLES I thought I would give my recent thoughts from testing a number of very different RCA interconnects.
Chord Crimson & Chamelon, Nordost Red Dawn, Mark Grant G1500HD and Van Den Hul First ultimate.
Cables (analogue) do sound different and in my experience based upon testing above with a friend in toe in general agreement. Listening level quite loud for reference.
Part of noticing differences I think maybe also be due to there being so many other factors involved which also have a bearing on sound or perceived sound. Of course you cannot magically alter sound to be something vastly different than your other component are exhibiting, however they can allow components to reveal more or accentuate more.
Another post stated this and I tend to agree.
Also, listening over a period of time usually more decisive and so makes ABX testing tricky.
Also having mains noise has affected my system performance I am convinced which maybe why I am hearing more detail than before and perhaps why different RCA cables are sounding different because less noise pollution affecting it.
However, a few differences I subjectively noticed, along with a good friend with good ears as well were around:-
Soundstage bigger on more expensive cables tested. Not having ever heard a good soundstage was something new I discovered so sure I did not imagine it.
Some cables can emphasize bass/mids/treble more or less which may suit one person more or less.
Some cables presented the music more forward into room and so that didn’t sound like coming from the speakers.
To say RCA cables do not affect sound is misleading.
As an example who has tried nordost red dawn interconnect? This has quite individual characteristics and would be a good test example. I would be surprised if most people couldn’t tell the difference between this and another generic interconnect….given used in a well balanced system.
So I am a believer in Analogue Interconnects and also Speaker cable which I have both experimented with to tune the sound of my hifi to personal preference. IE Warm, full, musical and not fatiguing.
On digital I need convincing still and being a logical kinda guy can see how it seems less plausable for a coax cable to affect sound.
These are my opinions and not meant to spark further arguments. I am happy with the money spent and changes it has brought to my hifi system so only person I need to convince is myself, which I have. SO THERE!!
Ambrose
idc said:Thompsonuxb said:Cables do make a difference.
I agree cables make a difference. I do not see the point in saying anything else. The real issue is why do they make a difference, with some people, some of the time, in different hifis? Also, why is the reported difference not consistent?
Is your simple test sighted, blind comparison or ABX?
Your analogy with diamonds is a fail because you need to show a link between purety and sound quality. That is where all cable makers fail as whilst many make appeals to their build quality and components, none can show a link between that and sound quality. All they can do is suggest a link, as you have done. That is the rejection of science that I do not like about the way cable companies and cable believers behave.
Why will your test settle the argument? What about all the other sighted, blind comparison and ABX tests that have already been done? Why have they not settled the argument?
