I have a set of Dali zensor 1's and i like them, they don't have so much bass but if don't angle them (toe in) the sound is more neutral form the twetter and the balance is better.
I have som very old rubber feet for cd players,amplifiers... from audioquest (Not Q feet) i am using.... a tile on top of the feets (i think it's called, i am from denmark so i am not shure if it's called a tile) and some adjustable foam so i can angle them down or up, they are as high as they can be 375 mm or about 15 inches high from med desktop and to the top of my speaker.
I am think of getting those speaker stands i the near feature http://www.isoacoustics.com/isol8r155.php?id=speaker%20stands%20studio%20monitor%20isolation They costs just under 129 € with shipping and seem to be the best speaker stand at a reasonable price (don't kow if theres any better stands out there regardless of prize?)
Is there any alternatives to those stands you would recomend me to look at? Not more expensive then 129€ with shipping to Denmark, they need to be about 8 inches tall so the tweeter is at the right hight, but also something that will improve the sound, no matter what the materiale of the surface is under my speaker
I have had the need for stands for more then a year, so now it's time to get a bit more serious about getting som quality stand for my small speakers
