Hi all.
I have a Denon Heos HS2 drive which allows me to play music in zones around the house.
Unfortunately, the unit has a major fault whereby the part needed is discontinued and therefore makes the unit redundant.
Could someone recommend a similar multi room solution which will play through my existing wired speakers?
Ideally i want something a bit more cost effective than the 3k it cost to buy the Denon!
Many thanks
Many thanks
