denon 1910 and pro logic IIz
could someone tell me if this is anygood and how does it work with all sound modes(DD and true HD type modes)and what type of cables would be required for for it sa xt type or silver micro type,thanks.
It works best with 5.1 signals, be it standard Dolby Digital or the new lossless HD formats.
It is bascically a sound processing mode, similar to the one that converts 5.1 tracks to 7.1, but for the front. It takes cues/flags from the original sound track and places them in the height speakers, effectly splitting the front left or right stage.
I think it sounds excellent, you wont hear it constantly, but if you have rainfall, a large front end explosion etc. at the front stage it makes the whole front stage much more three dimensional.
I use the full fat QED speaker wire, not the micro stuff, but you could use it I am sure.
Thanks very much,would i get the same effects watching sky HD.
Yes definately, anything it receives in 5.1, movies, football etc will work, not so much with anything in 2.0 digital that it converts, still works, just not as good.
Also has the biggest effect where sat/sub systems are used, not as big difference on systems with floor standers as they have a larger sound stage any way.
