- Aug 10, 2019
- 2,556
- 5
- 0
Hello,
I bought a Denon 1610 AV/Receiver a couple of weeks ago and bought a
the Monitor Audio Vector 5.1 Speaker package today and am obviously
keen to get it up and running as soon as possible.
My question concerns the Sub woofer connections and the MA literature
states that "the only method of input signal to the VW-8 is a RCA phono
input".
It also states that "a single cable from the "sub out" or LFE
connection on the amplifier to the RCA input connection on the VW-8
labelled "R". The RCA input marked "L" in this case will remain unused."
On the Denon 1610 it has three "holes"; the side is labelled PRE-OUT
and underneath it has a black "hole" with SUB WOOFER underneath, A red
hole which says SURR BACK underneath and finally a white "hole" with
FRONT HEIGHT underneath.
I understand the connection in the SUB but require clarification on what I stick where on the AV receiver.
I am just setting up 3.1 surround currently. If people are further
interested in helping I am connecting a SKy HD box, a X Box 360, a DVD
player and a Squeezebox classic. I am assuming that the X BOx, Sky and
DVD player will all go into the HDMI in on the amp but also unclear
where the Squeezebox goes in. I also assume I need to use an optical
cable in conjunction with my Sky HD box HDMI as I read some stuff
previously that this is the way to do it.
Thanks for any help
Mal
input".
Thanks for any help
Mal
