Blacksabbath25 said:
Yes i will do this time around and I will take a load of CDs and most probably my Yamaha amplifier just to compare
Sounds like you are on quite an adventure Blacksabbath. I always enjoy demoing loads of different options but sometimes it can be as frustrating as enjoyable in trying to find that balance between various bits of kit.
Just something to think about (and sorry if this confuses further rather than helps) but I was on the same merry go round as you in trying to find the best possible match between source/amp and speakers. With a lot of reading and speaking to people on here as well as other forums, I decided to take all the pain out of amp/speaker matching and buy active speakers and make the only variable the source (which I was already pretty settled on). It took me a while to get used to them but it's the best thing I ever did and now all I concentrate on is the music and the leap in sound quality was immense. I may be just about to order a second set of AE1's dependant upon a number of variables with moving other stuff on - they are THAT good.
And it's all Pedro 2's fault .
CNo mentioned earlier that you may want to try a Linn DS and these are reasonably priced second hand and of very high quality. Add in a pair of active speakers and you'll probably be within a sniff of what you'd spend on some of the other amps that you have mentioned. That's without taking into account moving on your own stuff which may make it cost neutral or low cost. It may just be worth a listen to rule it in or out as an option.
Sorry if that confuses you more so feel free to ignore if it's not for you. It just enabled me to get back to 'simple' hifi that was high quality and stop the eternal mulling over of 'what next'. However, you may actually enjoy the ride that 'what next' gives you so good luck with your demos.
