Dali Oberon 1 on Cambridge Audio AXA25
Nelis87
28
Hello all,
I am trying to put together a small and budget friendly stereo setup and settled on the Dali Oberon 1 and Cambridge Audio AXA25 (25 Watts). The Oberon 1 because I like the sound and the AXA25 +AXN10 because of the small (low) footprint, descrete looks and price.
The manual of the AXA25 sais to only connect 8 Ohm speakers and 6 or 4 Ohm speakers could damage the amp. The Dali's are 6 Ohm speakers. Could this really damage the amp or will it work just fine?
I am planning to us this system for low (background music) to moderate listening levels (listening sessions), never loud.
The AXA35 is not an option because I dont need any of the added features and I dont like the look because of the small screen.
Regards
Hello all,
Regards
You'll be fine with those speakers unless you intend to play at disco levels of volume.
Nelis87
28
Forgot to add that I would agree that 25wpc is somewhat poor in a modern amplifier that is probably going to be used with cheap inefficient standmount speakers.
What are you going to be using for a source of music?
I agree. I will be using Spotify and internetradio mainly.
Maybe I should look at Nad c316bee v2 which is about the same height and find myself a decent streamer.
I also like the Denon rcd n12 as an all in one.
Can’t decide!
Nelis87
28
Why the Denon if you don't need a CD player?
Think you really need to re-evaluate your priorities.
.....and do a lot more research
My priorities are clear, Spotify Connect and internetradio in a discrete package, suitable to drive the Oberon 1's. The Denon does all that so I consider it an option. For the local price of ~€475 I don't think unused features like a cd player and HDMI makes it any less suitable.
I still like the idea of a seperate amp and streamer better but I will pass on the AXA25.. the 25wpc concerns me to much. I will do some more research on other options, thank you.
If you can budget for it the Rotel A11 at £399 might be a better bet.
Rotel amps always have good current delivery and it's 50 wpc
It is quite slim.
