kemills1 said:Bits are bits and are perfectly conveyed to the dac from the digital source via optical or coax or usb. That’s what any digital engineer would probably say. I used to be one and that is what I would have said and I still do say it. So why do they all sound different? A raspberry pi driving a Bryston DAC sounds different to a Innuos driving the same DAC. I’ve listened to both on a pair of kef ref 5’s and a MF nuvista 800 and there really is a difference but why? Bits are bits. Change the the USB cable from a cheap one to a chord signature and the pi sounds different as does the Innuos but why. Bits are bits.
The Bryston has galvanic isolation so it can’t be ground induced noise, can it? It has extensive de jittering so it can’t be timing, can it? It’s digital so no lost data. So what is it? Who knows. All I do know is I will spend money on hifi if I think it sounds good to me and not because someone says it sounds better. And what is “better” anyway?
To say there is no difference between a pi and some dedicated dac less streamer when I can clearly hear a difference leaves me wondering why we all seem to have different experiences of digital sources when they should all sound the same. Bits are bits, right?
And the real kicker, swap a AQ vodka optical cable end to end and, to me, it sounds different!
Andrewjvt said:kemills1 said:Bits are bits and are perfectly conveyed to the dac from the digital source via optical or coax or usb. That’s what any digital engineer would probably say. I used to be one and that is what I would have said and I still do say it. So why do they all sound different? A raspberry pi driving a Bryston DAC sounds different to a Innuos driving the same DAC. I’ve listened to both on a pair of kef ref 5’s and a MF nuvista 800 and there really is a difference but why? Bits are bits. Change the the USB cable from a cheap one to a chord signature and the pi sounds different as does the Innuos but why. Bits are bits.
For helping me to waste 30 seconds of my life reading that bull ****
kemills1 said:I wrote the nonsense after a frustrating evening trying to understand why I could hear differences between different digital sources and I did consider what I was hearing was down to, as you say, “suggestion bias” but I’m sure there is more to it than that. I do wonder if the digital data has been taylored in some way in the digital domain by a DSP.
+1CnoEvil said:kemills1 said:I wrote the nonsense after a frustrating evening trying to understand why I could hear differences between different digital sources and I did consider what I was hearing was down to, as you say, “suggestion bias” but I’m sure there is more to it than that. I do wonder if the digital data has been taylored in some way in the digital domain by a DSP.
If you want to know what you heard, never believe your ears, but go onto a Hifi Forum and ask someone who wasn't there, to tell you. Simples. *wink*
Andrewjvt said:+1 This is good advice and will save you loads of wasted evenings mucking around. More time to use your equipment for its intended use.... Listening/enjoying not analysing music.CnoEvil said:kemills1 said:I wrote the nonsense after a frustrating evening trying to understand why I could hear differences between different digital sources and I did consider what I was hearing was down to, as you say, “suggestion bias” but I’m sure there is more to it than that. I do wonder if the digital data has been taylored in some way in the digital domain by a DSP.
Was Danny discussing cables .... ? ;-)CnoEvil said:Andrewjvt said:+1 This is good advice and will save you loads of wasted evenings mucking around. More time to use your equipment for its intended use.... Listening/enjoying not analysing music.CnoEvil said:kemills1 said:I wrote the nonsense after a frustrating evening trying to understand why I could hear differences between different digital sources and I did consider what I was hearing was down to, as you say, “suggestion bias” but I’m sure there is more to it than that. I do wonder if the digital data has been taylored in some way in the digital domain by a DSP.
I'm the Danny Dyer of the HiFi forum.
(Don't worry if this doesn't make sense, as it's a rather obscure reference to a very recent clip (with Piers Morgan) that went viral...where he made a comment that seemed to unite both sides of THE current polarizing debate.)
Kubs said:Was Danny discussing cables .... ? ;-)
woodbino said:Of course it sounds different. It always will.
Listening and hearing involves a lot of post processing, and that happens in thee brain. Your mood, expectations, what your wife said to you in bed last night, this will all change the sound.
90% of what you all say and describe about the sound quality on these forums is based on these variables, not the electronics in front of you.
It's all good though!
Gray said:I've just read this review of a streamer.
https://www.whathifi.com/moon/neo-mind/review
There's no built in DAC and 'the app could be more intuitive'. So what have we got?
A £1700 box that passes files out to a DAC of your choice. The DAC used for the review was the Chord 2Qute.
The 4 bullet points in the review's 'for' column all describe the sound quality and are very encouraging - but.
Wouldn't you think that the positive findings are more to do with the DAC than the streamer?
Forumites have often made the point that a bit perfect file is all the DAC needs. My Raspberry Pi sends a bit perfect file to my DAC. So can anyone tell me how this streamer could send the file any more perfectly?
Or give me any reason why it would sound better than the Pi?
CnoEvil said:Kubs said:Was Danny discussing cables .... ? ;-)
No. Something even worse. *unknw*
kemills1 said:I’m beginning to think none of these streamers send bit perfect data to the dac. And the servers for the streamers don’t send bit perfect data either. I wonder if anyone has ever captured digital data from various streamers and done a bit wise comparison of the data stream. I can’t help but think the analogue output has been manipulated at every stage of getting the music to your amplifier.
He was giving his views on Brexit with particular attention on David Cameron.jjbomber said:CnoEvil said:Kubs said:Was Danny discussing cables .... ? ;-)
Cr-Apple? Actives? Brexit? For goodnes sake, put us out of our misery!!
I know his daughter and son-in-law are called Jack and Dani. Cockney slang never got it so right!
Gray said:Forumites have often made the point that a bit perfect file is all the DAC needs. My Raspberry Pi sends a bit perfect file to my DAC. So can anyone tell me how this streamer could send the file any more perfectly?
Strictly Stereo said:That line "a bit perfect file is all the DAC needs" is either a gross over-simplification or just plain wrong. DACs do not deal with files. DACs deal with streams of bits, either PCM or DSD. Streamers like the Neo MiND or a suitably configured Raspberry Pi take files and turn them into streams of bits. With a PCM or DSD stream, the sample rate is encoded in the data rate, rather than the bits themselves. Timing errors in the output have measurable effects. Many modern DACs attempt to fix or avoid such errors in the source, but DACs themselves can also introduce errors.
andyjm said:You seem to be mixing up all sorts here.
It’s all a Matrix Electro.Electro said:If this is true it is very worrying indeed, how on earth am I surposed to tell what is real in my life, or if indeed the whole world is purely in my imagination.
Do I exist or am I a figment of my own imagination, but if I don't exist how am I imagining myself ----------- *help*
Strictly Stereo said:I have not heard the Neo MiND and I have no idea which particular combination of Pi, HAT and software you are running, but I would encourage you to compare them for yourself. I am sure that your local Moon dealer would be happy to offer you a demonstration. If you cannot hear a difference and you have no other reason to switch, then I would recommend that you hang on to your money.
