CnoEvil
LevK
I now have further information for you.
As I suspected, the Vincent T.A.C SV 236 has had an upgrade to the SV 236 MK
The original mark 1 : 100w into 8 ohms / 180w into 4 ohms....if this is the amp you were sold, then you need to make sure you got a good discount, as the new model has been around since at least 2009.
This amp was Editors choice (Absolute Sounds Mag) for several years, and is known for its remarkable value for money. It's a German amp made in China (to German standards/specs)
The new model has an extra 50w (as per my spec above), upgraded power supply with voltage stablization and a few wiring changes.
Also check out the review by "6 moons"...all this should help put your mind to rest.
Cno
Cno
