BH:
Got the option to buy an ex-demo Cyrus or a used arcam alpha 8, there is £200 in difference between the two - thinking of pairing it with a beresford DAC to play music from a Mac. Any advice on which way to go? Initially I will be using MS 902i speakers, but will also upgrade those soon.ÿ
Have heard Arcam 7 which a friend has and also recently demo'd a new Arcam (don't know model but circa £700 new) against similar priced Rotel. On both Arcams, I found they lacked a bit of detail and, I don't know...not enough "ooomph" somehow. I ended up with 2nd hand Cyrus 8vs instead which I think was great value for money and I've been able to fine tune the detail to my liking and find warmer combinations pairing it with different components. Word of warning though - the combination of the Cyrus, MS902i and my original Technics CDP was bright and a bit (OK, in retrospect, "very") tiring to listen to, although swapping out the Technics for a Marantz CDP made it much smoother, as did change of interconnects. Like you I intend to switch the speakers, so I tried to disregard them from my decision-making re other components. To be fair about it, it'd be interesting to demo the Arcam again as my journey has definitely seen my taste change from preferring very forward to a somewhat smoother sound and just maybe I might not be so disinclined towards the Arcam now. Anyway, as always I guess it'll depend on your personal taste and also the sonic characteristics of the current Beresford since that's the component that'll be a constant for you. There's a good WHF video for newbies (like me, as you'll have guessed) on matching sonic characteristics of components - you'll find it elsewhere on this website under the 'videos' section (funnily enough!).
