Eurica . . . I have finaly cracked it. Since I moved house in 1996, I have never been able to recreate what I consider, was the perfect sound for my ears. The 80's was a golden decade for my hifi activities..
. . . sorry that sounds very big headed, appologies, all gone now, I'm just simple old all washed out CJSF.
One worked very hard to achive a siound signature in the early 80's, it did reap rewards. Over the past 5 or 6 years since I re kindled my interest in hifi, it has been a goal to get back to those good times performance wise. One followed the same principals although on a lower budget, but always fell slightly short, a big bit short on ocasions!
One more or less gave up by 2016, what with personal circumstances and all. In the past few weeks things have got better, I have changed my medication to good effect, up and at'um. Having gon back over the extensive work done on the TT over the years, I'm happy that short of major expence, I cant do any more. All my cables are original to that golden 80's era, no change there, same as the speakers, they were late arivals, replacing my LS35a's.
Which brings me to the Icon 45 amplifier. A lot less expensive than the EAR 509 mono blocks, plus the Icon is an intigrated unit . . . how do I turn a sows ear into a silk purse, is it indeed a sows ear? Again changes, not as extensive as the TT, I'm no electrical enginere, but such as I could I changed valves, yes valves do have diferent sounds and they dont have to be the most expensive to be what one is looking for.. I use a mixture of 'old stock' and used valves, only the 4 output valves are new Lion KT88's.
Getting to the valve compliment I have took a lot of time, sccowering the verious sellers ads, I'm using some Russan valves that are 30 year old, 'old stock' and only cost a few quid, also tried the latest and gratest at £200 a matched pair, I require 2 pair! Sent them back as not worth the effort. My Icon 45 uses oil/paper capacitors, dont even ask how much ****!! they work, but I do wonder about the wisdom of that particular purchase . . . ?
So still on the amplifier, the system was nearly there but I new it was not quite on the mark. About a year ago I read somthing about the big output valves crosstalk via somesort of radiated energy . . . yessss???? I'm not that gulable am I ???
No, I'm not but 'dont knock it untill you have tried it'. So I disapeared into the man cave for a few hours, re emerging with apropriate lead radiation shields . . . I did not bother with the yellow and black circle on them.*acute*
Not expecting anything from this experiment I was supised, a cleaning up of trebal and base . . . but one was still left with the 'a change but not quite right' feeling.
That was 9 months ago, recentley one has been doing quite a lot of listening, still got that nagging in the back of my mind . . . not right!! My mind processing has progresivly got better recently . . . I was in the 'man cave' the other day, working on my glider, needed a sealing ring, sealing ring . . . 25mm silicone sealing ring. Thats about the size of the three small regulating valves. A perfect sug fit, listenrd to some Spotify . . . I could hear it on Spotify, 'the sound' I had been looking for. Warm, detailed, open sound stage, all the nasties gon.
I put the TT and valve phono stage to warm up. All the pieces of the jigsaw are finaly fitted. An easy relaxed sound, excelent sound stage, the detail is amazing, I can hear harmonies and harmonics again that I new were there from my 80's system, leading edges are so sharp, I think even better than the 'original sound'.
A lot of hard work has finaly paid off, I feel with interest.
CJSF
CJSF
