sheggs said:
			Hi chewy,
The  Radio Shack metre is pretty good for tackling certain generic problems. The full room measurment software just takes it to that next level. It basically -
Will show your nulls and peaks in db's for all the different hz so you can identify problem areas
Produce waterfall graphs which basically show the decay time of these hertz (basically how long does it take for the sound wave to stop ringing)
Can identify not just hertz but exactly where it is coming from if you have (you'll be surprised how much people in studios have problems with reflections off the mixing desk) a specific problem
What a lot of people use it for as well is to trial different listening positons because sometimes the low cost solution to the problem can just be as easy as where you sit. (Hence the sitting on the floor thread LOL)
As the video demonstrates (thanks Voodoodoctor) is first reflection points are basically the first place that these sound waves hit when they leave your speakers. so this would generally (but not exclusively) be to the side of each speaker, the floor and the ceiling.
On the sides you only need to tackle those immediate spots one thin panel about one metre tall should generally cover it (unless you have floor to ceiling speakers) and these should be placed in line height wise with the speakers.
Ceiling clouds are more regularly used in studios and then you would cover the listening position and two or three panels would be required.
Just remeber the symetrial rule if you can though, to treat both speakers the same
Thanks for coming back to me,
Sorry, I probably didn't make it clear in my post, I already have and use REW, but use it currently with the Radioshack SPL meter as the mircophone. My question was, will the Behringer produce more accurate measurements with REW?
Regarding panels for the first reflection points, yes, my plan was to make 1200 x 600 panels, since these are the size of the Rockwool boards I believe. I would then be placing these on the walls around 200mm off the floor, and hence they would finish a little above seated ear height.
Still, there is a heck of a lot of wall coverage to cover all first reflection points for two seating position, from all three front speakers, with a 20ms or less delay time. See below:
http://www.flickr.com/photos/dsmstainlessproducts/7703932164/in/photostream/lightbox/
(Can't get the damn image to appear on the face of the post?!?)
