- Aug 10, 2019
- 2,556
- 5
- 0
Dear all
I am still seeking the definitive answer to this question.
I have a pioneer VSXAX10ai with a phono stage earthed input to which I want to connect a moving coil cartridge turntable (Project 2 X perience ). Can some one tell me is it just a connection with the phono leads and earth cable or will I need to connect to another phono input with a separate phono stage because of the low voltage? I ask this as I was told different things by Pioneer & Project technical support.
Regards
Saab
Regards
Saab
