Compare Marantz Dacs
Shrek
1,267
806
6,070
First time ive ever compared Dacs on my CD60 & 70s. connected via RCA & Optical, first time with Optical .Lisening to the same track and switching directly from one to the other ,I'm very surprised how completely diffrent they sound.I havent decided yet what one i prefer.Just a observation .time will tell what one i prefer . still shocked at the diffrent sound outputs.
Reactions: manicm
That was the first thing i noticed the CD60 is much lower but at the moment i think it does sound better still comparing them.
Marantz always did use output level to make their players sound more impressive than others, so it wouldn't surprise me if they upped the outputs of models higher in the range for the same effect.
Exactly. And you only need a very small difference to get the impact. Less than 1 dB is sufficient to stand out.
I believe your CD60 is higher up the Marantz ladder compared to the amp, and they typically use better chips in their cd players to begin with. So it's to be expected that your CD60 DAC is technically better, more accurate and detailed.
Assumptions like that are the reason why i don't take the time to compare properly. You're absolutely right to do so, and i'd be interested to know what you eventually prefer and why...
Reactions: Shrek
Your right it is , more accurate and detailed i prefer the CD should have tried it in the first place .
Reactions: PieterG
