Comparability of 5.1 speakers Philips HTS2500 and Yamaha Rx-V457
Petherick
122
18,595
Hi
The Philips speakers may work except the subwoofer. The reason is that the sub is passive (has no amplifier in) and the Yamaha is designed to use an active sub.
I suggest you try to budget for other speakers. Maybe if you buy them at the same time as the amp you can get a discount.
Benedict_Arnold
661
All in one box home cinema speakers are generally fine for the surround sound aspects, but as Petherick says, you need to budget for a separate powered subwoofer and ideally some decent front speakers as well. The all-in-one-box centre speaker should be fine as well.
Most all-in-one-box systems use the subwoofer case to house the pwoer amplifier(s) for the entire system, which is why the control unit that sits under your TV can be so small.
