stevebrock
- Nov 13, 2009
- 183
- 1
- 0
jcarruthers said:At least wait until your Exact wears out then 🙂
The connectors are easy to get off — unlikely to break.
i dont think it will be long
stevebrock said:Excellent Andy,
The only thing that I worry about is disconnecting the connections from the Exact - worried that I might snap them.
I still dont know if I should go for it as nothing wrong with my Exact but I like the option that you can replace the stylus on the Concept - is that right Andy?
plastic penguin said:Good stuff. So it's better than the Elys but no better, yet, than the Exact. Sounds about right.
stevebrock said:Andy, how much did your raise your arm?
stevebrock said:I could probably get £120 for the Exact on eBay, so wouldnt really cost much to change to the Concept MM - still very tempted!
plastic penguin said:stevebrock said:I could probably get £120 for the Exact on eBay, so wouldnt really cost much to change to the Concept MM - still very tempted!
How long have I been preaching the virtues of ClearAudio carts? Does anyone listen? no.
stevebrock said:plastic penguin said:stevebrock said:I could probably get £120 for the Exact on eBay, so wouldnt really cost much to change to the Concept MM - still very tempted!
I don't know - can you please enlighten us 🙂 🙂 🙂 🙂
plastic penguin said:stevebrock said:plastic penguin said:stevebrock said:I could probably get £120 for the Exact on eBay, so wouldnt really cost much to change to the Concept MM - still very tempted!
Over most cart threads in the past two years I've banged on about their strengths.
Okay... I spent the whole morning at the Rega dealer (could've been afternoon - it was six years), he connected up a Ortofon (can't remember the model ) costing about £100, which had a slight uplift compred to the Ortofon fitted with the TT. Thereafter, he switched to the ClearAudio (£110) and it was clearly audible the clarity had improved, subtle detail and insight was fairly immediate. The bass, although not lean, was very taut which highlighted the midrange a little more. Overall well worth spending the £70 over the budget Ortofon.
Also pointed out when I had the Rega dac on home trial the same dealer, who's still a Clear Audio cart supplier, said the Classic Wood wouldn't have a problem if fixed to a RP6, easily as good as the Exact, possibly better if you like the sound. Remember I was hearing all these improvements from my £200 Xpression TT.
This is a very exclusive club. :dance:
was only kidding fella!
anyway thanks I am more or less decided - gonna give one a go!
So the Concept MM is just a white version of the Classic Wood isnt it
andybeau said:was only kidding fella!
It's a slightly different cart to classic, virtually the same spec tho and lighter than the ally version by 1.6gms
Looking on there website they don't show the classic anymore but they are still available elsewhere.
Concept
plastic penguin said:andybeau said:was only kidding fella!
Concept
Think it must be a direct replacement for the Classic Wood.
There's two components I wouldn't contemplate changing in the short/medium term: My amp and the Classic Wood cart. Can imagine it sounding equally impressive on a Gyro as well as a budget Pro-ject.
