Chord Odyssey 2 or Atlas Hyper 2.0 for my B&W 685?
Hi everyone,English is not my first language,I hope you guys can understand my post~
Here is my system below:
Apple lossless > Cambridge DACmagic PLUS > Wireworld Oasis 6 > NAD C375BEE > QED Silver Anniversary XT > B&W 685
My problem is the QED SA XT speaker cable sounded a little hard(bright?) and lean for me. What I need is balanced and dynamic sound,smooth/natural treble,warm/detailed middle,punchy/clear bass.(Excuse me for my poor adjective 😛)
So will Chord Odyssey 2 or Atlas Hyper 2.0 be my proper choice? Of course,any other suggestions are welcomed~
Thanks a lot~
Slowest forum Ive ever been on.
I would try some VAn Damme Blue or OFC, that is only about £2 a metre if no good sell it on for very little loss. Certainly several people find the VD better than more expensive cables.
Here is a post: http://www.whathifi.com/forum/accessories/van-damme-blue-bargain-of-the-century
and here: http://www.whathifi.com/forum/hi-fi/just-upgraded-to-the-van-damme-lc-ofc
stevebrock said:
if your finding it too bright then maybe the Atlas as the Odyssey is silver!
Thanks for your reply~
so you mean...I should find some cable without plating silver?
Thank you,BigH~
I will consider it~
I recently was given a pair of Atlas Equator 2.0 OFC speakercables, and they made my Monitor Audio RX8's highs softer compared to the Chord carnival silverscreen and the Epic's I have.
Mmmm,how disappointed,I searched the dealers local,they have no Van Damme cable to sell...
Are there any high cost performance copper cable recommended?
Have a nosy here: http://www.whathifi.com/forum/hi-fi/speaker-cable-tests-and-results-from-last-nights-fiddling
Similar system to yours; hope to help 🙂
Andy which country are you in? There are several dealers that stock it in UK, some are on ebay.
Great~!!!
You are appreciated!
I'm in China~🙂😛
I'm in China~🙂😛
[/quote]
I see. The only one is in Hong Kong called Rumble, if you check the Van Damme website there is an email contact.
Thank you,BigH~
The shopping between Hong Kong and Mainland is a little difficult~ Anyway,I really appreciate your reply and recommendation~
:cheers:
If you can get it readily you'll not go wrong with the Odyssey 2 or Carnival Silverscreen but both the QED Silver Anniversary XT and Revelation (again if available) should be considered 🙂
