Chord Company Carnival SilverScreen vs QED XT Evolution speaker cable
The xt evolution is a nightmare, lucky I only needed 1m, as I threw it away.
You need to clip the ends as they wont go in bare. will stick to the regular QED XT, so I would say Chord
Thanks for that but i tend to get them terminated.. will that make a difference ..i heard that the chord is quite hard to route ???????
8009514
72
Great speaker cable it may be, but I took one look at the Silverscreen and realised there was no way I could use it. Its nearly as thick as a hosepipe and not too pliable either. Not easy to hide it.
I have The Chords and they are as thick as waterpipes, so if you need to hide them under a carpet or something like that, they are not the choice, I have them hidden behin furniture so had no problem with them being thick, regarding the sound they sound really clean and balanced, i really loved them at first listen compared to a 14AWG transparent OFC cable i had which was a bit cheaper..
