Chord Chameleon Silver + I/C
Oh no I forgot to paste the url LOL
Yes I saw the £7 ones
I was looking at these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&Item=350199745470&Category=116852&_trkparms=algo%3DLVI%26its%3DI%26otn%3D2
It says for GOLD, does it matter though?
Pmaninit:
They are suitable for gold,silver and base metals so should be ok
basshound:Pmaninit:
ÿIt says for GOLD, does it matter though?
ÿ
Thanksÿ
How is the Chord now?
ÿ
Honestly mate, don't waste your money when Brasso will do the same job. It's a metal cleaner and worked wonders for my contacts. Couple of quid. Don't forget the fuse contacts too; never ending amount of dirt comes off those!
JoelSim:basshound:Pmaninit:
ÿ
Thanksÿ
ÿ
Well I`ve included it in my sig so that should tell you something!
Pmaninit:
You can buy alternative to Brasso called Silvo from same company used to clean silver staff.
Bought it for less then 2quid and it works really nice.
lazar1980:Pmaninit:
ÿ
Thanksÿ
ÿ
ÿ
Thanks, but does it have a 'suitable for nerds' symbol on the instructions? If it doesn't then it rules me out.
ÿ
igglebert:Silvo is too bright for Arcam users, you need Brasso...
Thought Arcam was supposed to be warm...
Silver thingies work well with Arcam, brings out superb detail with little brightness and certainly nothing harsh. I've got silver mains, interconnects and speaker cable and the sum is great.
ÿ
