Hi
Has anyone bought and are currently using this particular HDMI cable and if so is it any good?
Selby said:Thanks for the insight. Very helpful indeed.
Selby said:Hi
theflyingwasp said:I have no comment this time.
buzz_lightclick said:Nope it's a more expensive cable, still £150 for a mere 0.75m here:
http://www.futureshop.co.uk/chord-hdmi-active-resolution-075m-p-9098.html#.U3MmWdq9KK0
The marketing blurb talks up the 6mm diameter so it is a lot thinner than the chunky Chord Active Silver Plus, so maybe that accounts for the difference?
bigboss said:How does picture detail tighten up? What do you mean?? :?
mr malarky said:bigboss said:How does picture detail tighten up? What do you mean?? :?
i've often been distracted by the 'looseness' of my picture, maybe I should give them a go.
gel said:buzz_lightclick said:Nope it's a more expensive cable, still £150 for a mere 0.75m here:
That's crazy money! Just buy this one:
http://www.whathifi.com/review/audioquest-pearl-hdmi
ellisdj said:Yes use them yes they are good - if your not on.a wind up trying to create a thread full of arguements and controversey.
Thats whats coming....
